<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Trek Marlin 5 gen 3 suspension]]></title><description><![CDATA[<p dir="auto">Hi, I've got a trek Marlin 5 gen 3 (size ML) and I want to replace the fork. Sadly I cant put a tapered fork on it because it was supposed to have a straight fork. Does anyone know how I could put on a tapered fork and what fork should I put on. (preferably fox or rockshox.</p>
]]></description><link>https://www.bikology.com/topic/1050/trek-marlin-5-gen-3-suspension</link><generator>RSS for Node</generator><lastBuildDate>Mon, 25 May 2026 17:38:33 GMT</lastBuildDate><atom:link href="https://www.bikology.com/topic/1050.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 16 May 2026 05:08:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Trek Marlin 5 gen 3 suspension on Sun, 17 May 2026 19:55:21 GMT]]></title><description><![CDATA[<p dir="auto">Recons or judys might fit , i will see if i can find one. Thanks</p>
]]></description><link>https://www.bikology.com/post/5905</link><guid isPermaLink="true">https://www.bikology.com/post/5905</guid><dc:creator><![CDATA[Campbell]]></dc:creator><pubDate>Sun, 17 May 2026 19:55:21 GMT</pubDate></item><item><title><![CDATA[Reply to Trek Marlin 5 gen 3 suspension on Sat, 16 May 2026 11:08:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/campbell">@Campbell</a> you could put rockshox recons</p>
]]></description><link>https://www.bikology.com/post/5903</link><guid isPermaLink="true">https://www.bikology.com/post/5903</guid><dc:creator><![CDATA[dylan13]]></dc:creator><pubDate>Sat, 16 May 2026 11:08:29 GMT</pubDate></item><item><title><![CDATA[Reply to Trek Marlin 5 gen 3 suspension on Sat, 16 May 2026 06:52:07 GMT]]></title><description><![CDATA[<p dir="auto">hey, i had the same problem as you until i got a frame with a tapered headtube, i never found a method to fit a tapered fork into a frame thats not designed for it. as far as brand new you can get a rockshox judy with a straight steerer tube, or manitou makes a couple forks with a straight tube as well, but if you don't mind an older fork fox made a few straight tube forks around the 2010's, like the vanilla rl or the float rl. and for a while i used knockoff branded forks from aliexpress and they are surprisingly good. hope this helps and i wish you luck in finding something <img src="https://www.bikology.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=0ddcace847f" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title=":D" alt="😄" /></p>
]]></description><link>https://www.bikology.com/post/5902</link><guid isPermaLink="true">https://www.bikology.com/post/5902</guid><dc:creator><![CDATA[riggedupgaming]]></dc:creator><pubDate>Sat, 16 May 2026 06:52:07 GMT</pubDate></item></channel></rss>
